Ford Mustang AOD getriebe?
Re: Ford Mustang AOD getriebe?
AOD's out of a 4WD- Bronco are NONSENS, useless!!!
Stupid suggestions!
:roll: Heiner...
And be avoid of trannys out of a full size ford, by the tall tail shaft.
BadBorze
Beitrag von BadBorze »
thrice hat geschrieben: An AOD-E is not an AOD - the trannys from the other ad neither. :evil:
yes, might be, but remove the E, get better gear ratios and fitting issues are similar.
how to fit, wizard or not ...
aod:
First: 2.400:1
Second: 1.467:1
Third: 1.00:1
Overdrive: 0.667:1
Reverse: 2.00:1
4R70W:
First: 2.84 :1
Second: 1.55 :1
Third: 1.00 :1
Overdrive: 0.70 :1
Reverse: 2.32 :1
chris
- Buck Brannaman -
http://www.fordstrokers.de
