Butter bei die Fische, Kipphebel zu sehr eingelaufen?
Ringostar1982
Re: Butter bei die Fische, Kipphebel zu sehr eingelaufen?
Beitrag von Ringostar1982 »
Hab auch was dazu gefunden....
Valve-stem-guided-Beginning with the
.hydraulic-lifter version of the 1966-1 /2
289 and continuing in all small blocks
through some l~78s, rail-type rocker arms
are used. HP289s retain the early-style
pushrod-contrqlled rocker arms. Rails cast
into the end of th·e rocker arm straddle
the valve tip. These rails restrict lateral
rocker-arm movement by guiding against
the tip of the valve stem, thus the designation
rail-type. A clearance .hole is drilled
in the head casting for the pushrod. The
load of stabilizing the rocker causes valve
stem tips and rocker-arm tips to wear
faster than is the case with pushrod-guided
·. rocker arms. Valve guides are also .. loaded
laterally, causing them to wear faster
90° to their normal wear. .
As the rocker arm and valve-stem tip
wears, the rails get closer to the valvespring
retainer. There is no problem until
the rails begin to bear on the retainer.
This condition can proceed to . the point
where the keepers re 'lease, letting the
, valve drop into its cylinder .. Severe internal
engine damage is the usual result.'
Be aware of the danger of us.ing worn
valves · and rail-type rocker arms in your·
rebuilt engine. If the rails are close to the
spring retainers or are already contacting
them, don't take chances-replace the
roclser arms and valves.
Rail -Rocker- to-Spring-Retainer Clearance-
If your engine is equipped with the
rail-type rocker arms, which were standard
for all small-blocks from late 66 to 1977,
check the clearance between the rails on
each rocker arm and its spring retainer.
This dimension should not be less than
0.0625 in. (1/16 in.)- original clearance is
0.085 in. A not-too-common occurrence
is for the valve-stem tip. and rocker arm to
wear to the point that this clearance is
completely gone. As a result the rockerarm
rails begin to bear on the spring retainer,
eventually causing the retainers to
come loose. I mentioned this earlier in
the teardown chapter, but because of its
importance I'm repeating it. A dropped
valve can literally destroy an engine, so be
careful when checking rocker-arm-tospring-
retainer relationships.
Locate each rocker arm in its normal
Head Reconditioning 6
and Assembly
1969 Boss 302 Mustang engine with its unique cylinder heads. The
major objective behind this engine was to provide a practical
production engine that would be the basis for the strongest and
most powerful 5-liter (302 CID) engine for competition in the
SCCA Trans Am racing series-it was and they won. Photo courtesy
Ford.
position on its valve-stem tip and measure
the clearance between the rails and the
spring retainer. A six-inch scale is handy
for doing this, or use a 0.0625 in . thickness
of steel or aluminum sheet as a feeler
gauge. Discard any valve and rocker-arm
combination under the 1 /16-in . limit. The
reason for replacing the rocker arm too is
that excessive contact wear on one component
means the other component is
also too far gone-it will have also worn
in an erratic pattern. So, if the old rocker
arm were to be used with a new valve,
there would be excessive valve-tip loading
causing accelerated valve-tip and rockerarm
wear .
mit freundlichem Gruß
Steffen
derSchwabe
1980 Ford F100 Stepside
Beitrag von derSchwabe »
Abend zusammen,
Seeehr interessant.
Ich werden morgen mir die anderen Ventile nochmal genauer anschauen und auch mal den Mindestabstand von 1/16 Zoll prüfen.
Vielen Dank für die vielen Infos.
Eine große Überholung steht ja nun definitiv an, eine schöne Herbst-Arbeit.
Bin jetzt schon gespannt wie der Rest der Köpfe / Ventilführungen aussehen.
Ich halte euch auf dem Laufenden.
Vielen Dank nochmal.
Max
derSchwabe
Abend zusammen #2,
Nur zur Vollständigkeit.
Hab mal die Fühlerblattlehre gezogen, nach ein paar Versuchen habe ich dann ein Ventil gefunden bei dem das 1mm Blatt durch ging^^
Bei 1,58mm mindestabstand und 2,16 original ist das ja echt nett.
So um die 0,8 waren die meisten.
Die Köpfe sind übrigens mit DateCode 7D16, also 67, April, 16ter.
Frohes Schrauben.
Max
vegas
Mustang Fastback 66 289
Mustang Cabrio 67 289 Resto
Citroen 2CV 85
Mitsubishi Pajero
Renault Laguna 2.0
Renault Laguna V6 3.0
Peugeot Expert
Wohnwagen Eriba
Beitrag von vegas »
Eher Jahrgang 77 ;)
Gruss Daniel
derSchwabe
Soo,
und das beim schönsten Wetter....
Alles Originalmaß (Kolben, Ventile, Lager)
Zylinder habe kaum Riefen, (erklärt die verhältnismäßig gute Kompression) aber dafür eine deutliche Kante, wird also auf das erste Übermaß gebohrt.
Ventilführen haben 0,5mm Spiel, also das zehnfache des erlaubten^^
Schaftdichtungen waren hart wie Stein.
Köpfe sind C60E!
Eine Frage, welches wären die richtigen Ersatzkolben bezüglich der Verdichtung?
Oder sollte ich sicherheitshalber die Original Ventiltaschen auslitern und rechnen?
https://www.summitracing.com/int/parts/ ... /make/ford
Gegen ein bisschen mehr Verdichtung hab ich nichts ;-)
Max
Hallo Max,
so wie die Zylinderwände aussehen gibt es NULL Grund das Ding zu bohren. :?
Einmal ganz leicht durchhonen und mit neuen Ringen - wenn Du möchtest auch neun Kolben - zusammenbauen.
Als Kolben würde sich der KB 115S anbieten, hat keine Mulde und nur 2 Ventiltaschen, daher ist mehr Verdichtung (eher wie ein A-Code) gegeben.
Für die Köpfe sehe ich zwei Alternativen:
- einmal alles neu, von Führungen, gehärtete Sitzringe über Ventile, Federn und Retainer - richtig gemacht wird das TEUER :shock:
- oder ab ins Regal und für das gleiche oder weniger Geld neue Köpfe. (Windsor Jr. z.B für um die $850)
ich würde DRINGEND letzteres empfehlen
derSchwabe
Hi Michael,
Sehr interessant was du schreibst. Also die Zylinderwände sind alle gleich "gut".
Anbei ein weiteres Bild.
Ich dachte wegen der Kante oben am Zylinderende die ich deutlich mit dem Nagel spüren kann muss ich neu bohren lassen.
Geht das auch mit Honen weg?, oder ist es egal ob da eine Kante ist.
Kompression war 8.0 am schlechtesten und 8.4 am besten Zylinder (WOT, warm)
Das mit den Köpfe ist echt schwierig für mich zu entscheiden.
Ich könnte die alten für knapp 600 komplett überholen, allerdings ohne gehärteter Sitze.
Die Windsor JR oder die Flow-Tek hatte ich schon mal angeschaut, aber ich dachte da brauch ich wieder andere Krümmer etc..
Vielen Dank
Max
Hallo Max,
komplett überholen ist inkl. gehärtete Sitzringe - alles Andere ist halbherziger Murks. :?
Anhand der Bilder sieht mir der Absatz mehr nach Ablagerungen als nach Verschleiß aus.
Daher würde ich den, von mir beschriebenen Weg gehen - und nicht gleich einen schönen original Block zu bohren. So was bekommst Du nicht wieder.
Gehe mal mit Reinigungsfließ oder 00er Stahlwolle über die Kante und poste nochmal ein scharfes Foto.
Die Windsor Jr. lassen sich 1:1 montieren, benötigen nur gehärtete Stösselstangen - sonst kann alles 1:1 übernommen werden.
Entscheidender, ob Du den Block anfassen solltest, wäre ein Druckverlusttest gewesen!
What ever, wenn es nur um die Köpfe geht empfehle ich auch komplette Aftermarkschädel.
Was Du entgegen einer Komplettüberholung incl. gehärteter Sitzringe sparst, kannst Du sinnvoll in brauchbare Abgasführung investieren und erntest unterm Strich Mehrleistung.
derSchwabe
anbei nun das große scharfe Bild von der Kante:
KLICK 1
KLICK 2
Ich bin der Meinung das wenn ich eine Blattlehre mit 0.1mm dran halte dann mit dem Nagel glatt drüber streichen kann, also eben bin.
zu den Köpfen,
die Windsor JR wären dann die https://www.summitracing.com/int/parts/ ... /overview/, oder?
Der Preis ist aber Stück?
Achja, Nur als Ergänzung, ich hatte beim Kompresionstest mal etwas öl eingekippt und bin dann 0,5bar höher gekommen.
Der Grund warum ich die Kolben nun auch machen will ist weil es mir geraten wurde, da es unsinnig wäre das oben alles dicht und unten alles alt ist wäre. (Nachbar bei Mercedes)
Schönen Gruß und vielen Dank für eure Hilfe.
Max
