Erwins Teileliste ab 11 / 06
Erwin
Fuhrpark: 68 er convertible
200 cui
Beitrag von Erwin »
Hallo zusammen
Do. 23.10.08 stand 27554,23
Heute mal ein Paar Teile bei Johannes bestellt , morgen wirds weiter gehen .
| 3 | SC-CAR65-CV-DB | 65-68 Cabrio Teppich kompl[..] | 179,99 ? | 1 | 179,99 ?
| 4 | MS-GRT5847 | Mustang Hupknopf für Grant[..] | 34,99 ? | 1 | 34,99 ?
| 5 | MS-GRT3249 | Lenkrad Adapter für Grant [..] | 29,99 ? | 1 | 29,99 ?
| 6 | MS-GRT213 | Grant Classic Wood Wheel L[..] | 119,99 ? | 1 | 119,99 ?
| 7 | SC-C9ZZ-3468-D | Strut Rod Arm (with Nut, LH) | 62,99 ? | 1 | 62,99 ?
| 8 | SC-C9ZZ-3468-C | Strut Rod Arm (with Nut, RH) | 62,99 ? | 1 | 62,99 ?
| 9 | SC-C7ZZ-16A[..] | 67-68 Monte Carlo Bar (Str[..] | 29,99 ? | 1 | 29,99 ?
| 10 | SC-C8ZZ-185[..] | 1968 A/C control knob set | 34,99 ? | 1 | 34,99 ?
| 11 | SC-C7ZZ-650[..] | 67-68 Air Vent Assembly | 139,99 ? | 1 | 139,99 ?
| 12 | SC-C7ZZ-18A[..] | 67-68 Water Valve Bracket | 25,99 ? | 1 | 25,99 ?
| 13 | SC-C7ZZ-18A[..] | 67-68 Heater Box Assembly [..] | 280,00 ? | 1 | 280,00 ?
| 14 | SC-C7ZZ-18518-A | 67-68 Heater Control Cable[..] | 42,00 ? | 1 | 42,00 ?
| 15 | SC-C7ZZ-18500-B | 67-68 Heater Seal Kit with A/C | 16,99 ? | 1 | 16,99 ?
| 16 | SC-C7ZZ-18490-R | 67-68 Defroster Duct (No A[..] | 42,00 ? | 1 | 42,00 ?
| 17 | SC-C7ZZ-18490-L | 67-68 Defroster Duct (No A[..] | 42,00 ? | 1 | 42,00 ?
| 18 | SC-C7ZZ-184[..] | 67-8 with A/C Heater Core [..] | 39,98 ? | 1 | 39,98 ?
| 19 | SC-C5ZZ-18527-K | 65-68 Motor und Ventilator[..] | 94,99 ? | 1 | 94,99 ?
| 20 | SC-C5ZZ-18472-K | 64-68 Heater Hose & Clamp Kit | 23,99 ? | 1 | 23,99 ?
| 21 | SC-C5ZZ-18471-A | 64-68 Heater Plenum | 32,99 ? | 1 | 32,99 ?
| 22 | SC-C5DZ-18476-A | 64-68 Heater Core (without[..] | 44,99 ? | 1 | 44,99 ?
| 23 | SC-C7ZZ-762[..] | 67-68 Convertable door gla[..] | 374,99 ? | 1 | 374,99 ?
| 24 | SC-C7ZZ-762[..] | 67-68 Convertable door gla[..] | 374,99 ? | 1 | 374,99 ?
| 25 | SC-C7ZZ-762[..] | 67-68 Convertible LH Quart[..] | 329,99 ? | 1 | 329,99 ?
| 26 | SC-C7ZZ-762[..] | 67-68 Convertible RH Quart[..] | 329,99 ? | 1 | 329,99 ?
| 27 | SC-C6ZZ-650[..] | 65-68 Windshield Tinted, W[..] | 400,00 ? | 1 | 400,00 ?
| 28 | SC-C7ZZ-14300-E | 67-70 BATTERY CABLES(ECONOMY) | 39,98 ? | 1 | 39,98 ?
| 29 | SC-C7AZ-15052-K | 67-70 Cigarette Lighter | 19,99 ? | 1 | 19,99 ?
| 30 | SC-C7AZ-11450-A | 67-71 STARTER SOLENOID(CONCOUR | 43,00 ? | 1 | 43,00 ?
| 31 | SC-C0TZ-13A[..] | 1964-73 Headlamp Dimmer Switch | 9,98 ? | 1 | 9,98 ?
| 32 | SC-C7ZZ-5705-K | 67-73 6/V8 AXLE U BOLT EXC 428 | 8,50 ? | 4 | 33,99 ?
| 33 | SC-KYB343146 | 64-70 KYB GR-2 Shocks (Front) | 42,00 ? | 2 | 83,99 ?
| 34 | SC-C7ZZ-5781-A | 68-73 LEAF SPRING EYE BOLTS | 15,99 ? | 2 | 31,99 ?
| 35 | SC-KYB343219 | 64-73 KYB GR-2 Shocks (Rea[..] | 44,99 ? | 2 | 89,99 ?
| 36 | SC-C6DZ-5796-A | 67-70 Rear Spring Mounting[..] | 33,99 ? | 1 | 33,99 ?
| 37 | SC-C6DZ-5796-B | 67-70 Rear Spring Mounting[..] | 33,99 ? | 1 | 33,99 ?
| 38 | SC-C6ZZ-5776-K | 66-73 REAR SPRING SHACKLE KIT | 19,99 ? | 2 | 39,98 ?
| 39 | SC-C7AZ-622[..] | 67-69 Ignition/Door/Trunk [..] | 59,99 ? | 1 | 59,99 ?
| 40 | DISCOUNT | - 5 % Warenkorbrabatt | -216,63 ? | 1 | -216,63 ?
Versandkosten: 6,90 ?
Gesamtkosten Netto: 3464,57 ?
Gesamtkosten Brutto: 4122,83 ?
Stand 31677,06
Gruß Erwin
Gruß Erwin
Erwin
200 cui
Beitrag von Erwin »
Hallo zusammen
Stand am26.10.08 31677,06
Lieferung von uspartsonline.de
Spurstangenkopf aussen 2x
Spurstangenkopf innen 2X
Einstellmutter 2x
Umlenkhebel
252,57
gesamt 31929,63
Gruß Erwin
Gruß Erwin
Erwin
200 cui
Beitrag von Erwin »
Hallo zusammen
Stand am 11.11.08 gesamt 31929,63
Teile von Johannes
1. Cabrio sTANDART Sitzbezüge 244,99
2. 1968 Standart Interior Seat Cushions 139,07
3. Anschlaggummis Sitz Rücklehne 2x 27,98
4. Professional Hog Ring Upolstery Installation 29,99
5. Hog Ring Kit ( Bulk 500 ) 11,00
6. 68-69 Seat Latch Handle u.Bezel Set 29,99
7. 64-67 Kopfstützen für Standart Sitze 344,99
828,90€
gesamt 32758,53€
Gruß Erwin
Erwin
200 cui
Beitrag von Erwin »
Hallo zusammen
Stand am 16.12.08 geamt 32758,53 €
Motorenbauer 2000,-- €
mit Einfahranleitung und Garantie
gesamt 34758,53 €
Gruß Erwin
Erwin
200 cui
Beitrag von Erwin »
Hallo zusammen
Stand am 17.12.08 gesamt 34758,53 €
Lackierung in brittanyblue met. 4700,00
gesamt 39458,53
Gruß Erwin
Zurück zu „ERWIN's PONY“
