TCI Breakaway Torque Converter 451100 Wandler FORD C4
Gesperrt
Go4Gold
Fuhrpark: 1965er Fastback, 302cui (1972) mit Edelbrock 1404, C4 Getriebe (1972)
Beitrag von Go4Gold »
Biete hier wegen Fehlkauf (falsche Stall Speed) einen neuwertigen Wandler für FORD C4 Getriebe an. Er war nur wenige km verbaut bis klar war, dass ich einen anderen Wandler benötige. Technisch und optisch daher wie neu.
VHB: 549,- €
Neupreis (Sommer 2016) bei Velocity: über 700,- €
Versicherter Versand ist für 8,-€ möglich.
Technische Daten:
- Ford C4 (Dipstick Goes into Transmission Case)
- 10.5" Bolt Circle
- Non Lock-up
- 26-Spline
Features:
Furnace-brazed fins
Needle bearings
Hardened, pre-ground pump hub
Computer Balanced
Installed Hardware Included
Benefits:
Harder launches
Quicker acceleration
Improved low-end power
Bolt-in (no modifications required)
1000+ RPM increase in stall over stock
TCI 11-inch diameter Breakaway Torque Converters are designed for use in moderately modified street machines, weekend racers, and as daily driving use. Breakaway Torque Converters provide between 2400 to 2600 RPM flash stall without negatively affecting part-throttle driving. TCI has engineered these Breakaway Torque Converters to be efficient at highway cruising speeds and to launch hard at wide-open throttle. Each unit is built to meet or exceed OE specification and triple tested during assembly. Once all the prep work on the component parts has been completed, the impeller is welded to the front cover. Immediately following this process, a pair of dial indicators are employed on a rotating table to verify that the impeller body and pump drive hub remain true. Each unit is then pressurized and subjected to a leak test to confirm the integrity of all the weld seams. Lastly, each unit is computer balanced to reduce annoying and potentially damaging drivetrain vibrations that would occur from an unbalanced torque converter. That's Triple Tested so you can be confident you're getting a torque converter that's ready to roll.
Gruß, Daniel
Re: TCI Breakaway Torque Converter 451100 Wandler FORD C4
Boah ey! Haben wir Racer hier? :mrgreen:
Go4Gold
verkauft.
Gruß, Daniel
Gesperrt
