Liebe Kunden !
Für alle die an Ihrem Mustang Fächerkrümmer verbauen möchten haben wir hier nur noch 1 x unser TOP ANGEBOT:
64-68 Fächerkrümmer Tri-Y für SB / schwarz
Bolt-on horsepower and torque with Scott Drake Tri-Y headers. These headers are designed to fit 64-68 Mustangs with 260, 289 and 302 engines with automatic and manual transmissions. Although they look like average Tri-Y headers, these Scott Drake designed headers have been refined to provide ample clearance around the starter, steering and shock towers* for a superior fit. They are engineered to make strong power and torque throughout the RPM range with mandrel-bent 1-1/2" primaries, 1-3/4" secondaries and 2-1/2" collectors. Exhaust port size is 1-1/2" x 1-1/4". Each header is manufactured with heavy-duty features like extra-thick 5/16" laser cut flanges that have been machined flat to guard against warping and heavy-wall 16 ga mild steel tubing for superior durability. This header system is finished in black paint and includes high quality hardware, premium laminated metal core gaskets, and 2-1/2" – 2" starter tubes with collector flanges for a professional installation. Note: *1966+ motor mounts are recommended for proper shock tower clearance. Designed to work with common 157 tooth bell housings. Larger 164 tooth bell housings will require modification for proper clearance. Cars with power steering will require p/n DBPP-10961-A
ANGEBOT ! 64-68 Fächerkrümmer Tri-Y für SB / schwarz
Moderatoren: immerfernweh, elsterwelle, torf, All About Mustangs
- All About Mustangs
Mit freundlichen Grüssen
with kindest regards
ALL ABOUT MUSTANGS
WURM Ralf Martin
Essener Strasse 4a
57234 Wilnsdorf / Germany
Tel.: ..49 0176-5350 2225
ALL ABOUT MUSTANGS
WURM Ralf Martin
Essener Strasse 4a
- Krischen
- Fuhrpark: 65er Mustang Convertible, 289 cui, Schaltgetriebe
65 MY Ford Falcon 2dr Wagon
C170 1.6l Turnier - Wohnort: Leverkusen
Re: ANGEBOT ! 64-68 Fächerkrümmer Tri-Y für SB / schwarz
Hallo Ralf,
was sollen die Krümmer den kosten?
Christian
Christian
Hallo Christian !
Vielen Dank für die Nachfrage, da haben wir doch glatt den "Link" vergessen, siehe:
http://www.aamshop.de/64-68-Faecherkrue ... SB-schwarz
Brutto Preis 238,97 Euro zzgl. Versandkosten (oder Abholung Mo.-Fr. 9.00 bis 17.00 Uhr) ACHTUNG Brückentage 11.05. und 01.06.2018 geschlossen !
ALL ABOUT MUSTANGS
WURM Ralf Martin
Essener Strasse 4a
ALL ABOUT MUSTANGS
WURM Ralf Martin
Essener Strasse 4a
