email an Roy Jensen (National Parts Depot ) 23.03.09
- Fuhrpark: 68 er convertible
200 cui
Hallo zusammen
Hallo Roy Jensen
I have a 68er Ford Mustang convertible 200cui ,
Have you these parts on the store ? Please send the complete consigment because of the cargo .
1 new catalog for yourself Ford Mustang 1965-1973
Qty Item Number Description Price Prise X Qty
02 39322-3A Handle, Quater Window 7,95 15,90
02 23352 -3B Knob , Window Handle blue 4,95 9,90
01 39322-2K Mounting Kit 0,75 0,75
02 30702-01A Ash Tray conv. 17,95 35,90
02 30714-01A Ash Cover conv. 21,50 43,0
01 31486-7-2 Quarter Trim Panel conv. 149,95 149,95
01 QT-67-C Upholstery lt.blue 33,50 33,50
01 18808-2C Dual speaker 27,95 27,95
01 18842-1 Bezel Radio/Heater control 59,95 59,95
01 16720-1 Scoop,Hood Recess RH 59,95 59,95
01 16721-1 Scoop,Hood Recess RH 59,95 59,95
01 225-1LH Quoter Cover ,Coil Spring 47,50 47,50
01 225-1RH Quoter Cover ,Coil Spring 47,50 47,50
01 12A091-1 Distributor Vacuum Control 17,95 17,95
01 7A247-1AK Mounting Kit, Neutral Switch 3,00 3,00
01 KC-78-B Kick Panels , lt blue 24,95 24,95
01 9826-1 Clip,Accel Rod End Clevis 0,55 0,55
01 9737-2A Spring ,Accelerator Retrakting 15,88 15,88
01 380699-S Spring Clip,Brake Pedal Shaft 2,46 2,46
01 8419-1 Molding ,Radiator Grille 156,95 156,95
01 8243-2K Mounting Kit 10,00 10,00
01 8190-1A Grille opening Panel RH 21,50 21,50
01 8191-1A Grille opening Panel LH 21,50 21,50
01 8221-2A Lower joint cover 8,95 8,95
01 17747-1A Support braces 34,95 34,95
01 8242-2A Molding RH 12,95 12,95
01 8243-2A Molding LH 12,95 12,95
01 17A939-2K Mounts valence only 14,95 14,95
01 17754-1A Arm, Front Bumper 8,95 8,95 01 17755-1A Arm, Front Bumper 8,95 8,95
01 17757-2A Bumper , Front 95,95 95,95
02 17758-4AK Bumper Bolts small 0,85 1,80
01 17766-2A QArm/ Front Bumper 10,95 10,95
01 17767-2A QArm/ Front Bumper 10,95 10,95
01 17767-2K Monting Kit Front Bmpr Arm 10,00 10,00
01 17A869-2A Bracket,Front Bmpr 2,40 2,40
01 17A870-2A Bracket,Front Bmpr 2,40 2,40
01 17A924-1K Shim Washer ,Bumper Bolt 2,25 2,25
01 17996-3B Bumper Guard Front 32,95 32,95
Thanks Erwin
Haben alles da , nächste Woche kann ichs verbauen
Gruß Erwin
Hallo Roy Jensen
Thanks Erwin
Gruß Erwin
Gruß Erwin
- 69ShelbyGT500
Re: email an Roy Jensen (National Parts Depot ) 23.03.09
Erwin hat geschrieben:.....
Gruß Erwin
... was aber nicht der Normalfall ist ( nicht nur bei NPD sondern auch bei anderen US-Lieferanten ).
Ich habe eine Bestellung mit 5 Positionen losgelassen. Darunter ein komplettes Interior-Rebuild-Kit auf 66er Pony für Timo - Triple T.
Geliefert wurden ungefähr 40 Positionen, denn das Kit wurde auf einmal in Einzelpositionen aufgegliedert und man durfte dann selber nachprüfen, ob die Einzelpositinen auch das Kit ergaben.
Dann wurden aus der einen Bestellung 5 Lieferungen im Zeitraum von 7 Wochen, was aber in diesem Fall nicht so gravierend schlimm war, da ich eine Lieferadresse in den USA hatte ( Danke an ThoRich ).
Wenn es aber eine Direktlieferung nach good old Germany gewesen wäre, dann hätten mich die Frachtkosten aufgefressen.
Daher bei jeder Bestellung daran denken drunterzuschreiben:
Alles was innerhalb von z.B. 14 Tagen lieferbar ist, zusenden. Alles andere wird storniert und später nachbestellt. Ansonsten schicken die Jungs von drüben selbst eine fehlende Schraube per Extra-Fracht nach Deutschland
Gruß Erwin
Mit freundlichen Grüssen
Ralf Martin Wurm
57072 Siegen
Tel.: ..49 (0)176 5350 2225
eMail : info@69ShelbyGT500.de
Ralf Martin Wurm
57072 Siegen
200 cui
Hallo zusammen
Hello Erwin,
Here is the quote for the parts that you requested, FL--------
The estimated shipping charges for these items to you would be around
$300 to $350 dollars + / - depending on the final size and weight of
the boxes used to ship the parts to you in. I based this on two 62x7x25
boxes.
Please review the attached quote and let me know if you would like to
place the order at this time. If you are ready to place the order I will
need you to please confirm that I have your name, address, and phone
number listed correctly on the quote, and then provide me with your
credit card information to include: the full number across the front of
your card, the expiration date and the three digit ID number from the
back of the card.
Thank You, and have a nice day
Roy Jensen
Export Sales
NPD Florida
Mon to Fri 7am - 4 pm
Gruß Erwin
Hello Erwin,
boxes.
back of the card.
Roy Jensen
Export Sales
NPD Florida
Gruß Erwin
Gruß Erwin
- T5owner
- Fuhrpark: 1968 T-5 FB
Fahrrad/Roller
Würde mich überraschen, wenn das bei NPD 100% glatt läuft, aber man kann ja nie wissen.
Mir haben sie selbst vor Ort dreimal hintereinander die falschen Sachen über den Tisch geschoben. Hängt immer vom "Frontman" ab, ob der die Teile auseinanderhalten kann oder Chevi-Mann ist, denn NPD hat ja noch mehr auf Lager als Mustang-Teile. Aber jeder kann sich bessern und Roy Jensen öfter dran erinnern, daß Germany in Europa liegt:)
Viel Glück und ich drück die Daumen
Und erinner ihn noch, Rabatt vorher abzuziehen, bevor sie die Einzelteil-Positionen auflisten, ansonsten nimmt der Zoll gerne die unrabattierten Spalten. Manch US-Lieferant kann das aber nicht in seinem System.
Wolfgang
Moderator http://www.mustang-inside.de
200 cui
Hallo Wofgang
Schaun wir mal , müßte Mo. od. Di. hier sein ,
werde davon berichten , wie die Jungs drauf waren beim zusammenrichten ,
-- bei einem deutschen Händler , mußte ich 3 Monate auf den Servopum-
pendruckschlauch warten.
Nach 2 Jahre RESTO haut mich eh nichts mehr um, weis nur ,
daß ich zwischen Ostern und Pfingsten fertig sein werde , also mit der
RESTO !
Nur bei einem bin ich noch im Wanken , soll ich TÜV - fahren bei mir
um die Ecke , oder bei dem bekannten Prüfer vom Dachdecker , der zur
Werkstatt kommt .
Gruß Erwin
RESTO !
Werkstatt kommt .
Gruß Erwin
Gruß Erwin
200 cui
Hallo zusammen
Heute kommt laut laut UPS- all das bestellte .
Gruß Erwin
Gruß Erwin
Gruß Erwin
200 cui
Hallo zusammen
Die Teilelieferung von NPD- kam am Donnerstag , war alles komplett !
Hier der Lieferschein
am besten ist der neue 2009er NPD-catalog.
Gruß Erwin
Gruß Erwin
Gruß Erwin
- T5owner
Fahrrad/Roller
Der Beweis, daß sich jeder Lieferant mit schlechtem Ruf bessern...aber auch jeder mit gutem Ruf Mist abliefern kann. Es sind meist einzelne Personen, die den Ruf einer Firma bei einem Kunden ruinieren oder retten, selten der ganze Laden.
Wolfgang
