75€ zzgl Versand
Beschreibung von Summit inkl Teilenr:
Brand: Summit Racing
Manufacturer's Part Number: SUM-163289
Part Type: Harmonic Balancers
Product Line: Summit Racing® OEM Harmonic Dampers
Summit Racing Part Number: SUM-163289
Engine Balance: External, 28 oz. imbalance
Safety Rating: Not SFI-approved
Degree Markings: Yes
Degree Marking Range: 40 BTDC to 0 TDC
Outside Diameter (in): 6.405 in.
Harmonic Balancer Material: Nodular iron
Harmonic Balancer Construction: Elastomer
Harmonic Balancer Finish: Natural
Mounting Hardware Included: Yes
Quantity: Sold as a set.
Notes: Damper includes a bolt-in counterweight that can be removed for a neutral balance application. Set includes bushing and spacer kit for correct pulley alignment.
Description: These Summit® OEM dampers are ideal for those mild street rebuilds that don't require the expense of a high-buck race damper. They feature durable nodular construction with bonded elastomer between the inner and outer rings. They also have engraved timing marks, which means no timing tape!
