ich möchte einen neuen Harmonic Balancer von "Speedmaster" (Fluid Series) los werden. Sieht soweit gut und massiv aus das Teil. Wurde noch nie montiert.
Herstellerbeschreibung
Brand: Speedmaster
Part Number: PCE291.1024
Part Type: Harmonic Balancers
Product Line: Fluid Series
Engine Balance: External, 28 oz. imbalance
Safety Rating: Not SFI-approved
Degree Markings: Yes
Degree Marking Range: 50 BTDC to 10 ATDC
Outside Diameter (in): 6.625 in.
Harmonic Balancer Material: Steel
Harmonic Balancer Construction: Fluid
Harmonic Balancer Finish: Black painted
Mounting Hardware Included: No
Quantity: Sold individually.
Speedmaster race fluid Harmonic dampers are manufactured from forged K1045 low carbon steel and filled with high viscosity silicone fluid. A nylon ring and the nylon position guides allow the steel inertia ring to rotate freely inside the housing. The steel inertia ring rotates harmonically with the engine and absorbs the torsion vibration from the rotating assembly at any frequency and RPM. It thus extends the life of crankshaft and bearing and allows the engine to produce more power and torque. All dampers are tested to 12,500 RPM for explosion proof. They also feature clear, white, easy-to-read timing marks against a painted black background.
This damper is externally balanced; the term external balanced damper refers the built in weight or offset in the casting. When identifying your existing damper, (balancer) you must look on the backside. This is not visible if the damper is mounted on the engine. If your damper has no offset in the casting or weight, then you have an internal, (neutral) style damper. If you do see the offset in the casting or a weight, you have what is classified as an external damper.
VB sind 170 EUR zzgl. versicherten Versand
Bei Interesse, einfach PN
Beste Grüße,
matze
Harmonic Balancer 28oz Speedmaster Fluid Damper
Mazer
- Fuhrpark: Ford Mustang 66 Fastback (GT 350 Clone)
Mercedes AMG C30 CDI
Mercedes SL 350
BMW R 1150 GS
Vespa PX 200
- damper 3.jpg (19.57 KiB) 749 mal betrachtet
- damper 2.jpg (21.12 KiB) 749 mal betrachtet
- damper 1.jpg (21.1 KiB) 749 mal betrachtet
Beste Grüße - Matze
Re: Harmonic Balancer 28oz Speedmaster Fluid Damper
Ich glaube ich muss auch mal paar Teile aus den Staaten bestellen und hier anbieten um mein Taschengeld aufzubessern.
Das missfällt mir so sehr das ich das jetzt doch mal posten muss.
Warum? Weil das Ding drüben nicht mal die Hälfte kostet?
Mazer
Mercedes SL 350
BMW R 1150 GS
Vespa PX 200
100 USD+Versand+Onkel vom Zoll (Versand war sau teuer bei denen weil schwer??).
Kein Plan ob die mich beschissen haben, aber ich lag bei 190 USD all incl.
Sind ca. 170 EUR.
Dann hab ich VB angegeben was ja dem Betrachtier signalisieren soll, dass ich eventuell auch bereit bin runter zu gehen.
Hmm. Ansonsten bitte "realistische" Preisvorschäge via PN.
P.S.: Komme mit meinem Taschengeld über die Runden. Will mich hier net um 20 Euro bereichern.
Sind ca. 170 EUR.
Beste Grüße - Matze
