NGK od. Autolite
SchwarzStock
Fuhrpark: 65 Fastback
NGK od. Autolite
Beitrag von SchwarzStock »
In the past I have always had the best results with Autolite spark plugs. Currently I have NGK's but I am not very happy with the way the car is running, I think the plugs may be too cold. With the Autolites I was always able to increase or decrease the heat range to my car. I don't know anything about the NGK possibilities, any recommendations for a 302 with Aluminum heads?
HomerJay
Re: NGK od. Autolite
Beitrag von HomerJay »
No idea regarding the aluminum heads, but I only use Autolite platinums. Never had any issues with them.
JMS Bavaria
Beitrag von JMS Bavaria »
I drive aluminum heads with NGK sparks in a 302 and have no problems with it.
Jürgen
Jürgen
SchwarzStock
J,
what NGK's?
S
JMS Bavaria
These are the ones I Drive.
CheersBild
Jürgen
Jürgen
SchwarzStock
I have these, They load up at low RPM's, too cold?
JMS Bavaria
your spark is colder then my spark type.
BKR6EK heat range 6
TR55 heat range 5
See reference chart.Bild
Jürgen
Jürgen
SchwarzStock
I just bought a set of "5"'s. Had to go to two shops, they never have 8 plugs.....
