Ich verkaufe meine oberen Querlenker SPC Performance 94210, da ich die falschen für meinen Mustang bestellt habe. Ich habe einen 66er Mustang, aber dieser passt für 67-73er Mustangs. Dies gibt Ihnen einen "Shelby 1inch Drop", wenn Sie davon wissen
dieses Produkt. neu nie benutzt. Bei Interesse kontaktieren Sie mich bitte. Gruss Alain
500 Euro
Prioduct Info:
Modernize your early Ford and Mercury front suspension by installing adjustable upper control arms from SPC. SPC has built in 3° of caster to improve return to center with today's radial tires. The camber curve has been optimized by utilizing 'Shelby Drop' geometry in the billet aluminum cross shaft. The arm pivots are our maintenance-free xAxis Sealed Flex Joints for tight, responsive handling. Camber can be set to -1°, 0°, or +1° for superior cornering. Use this arm with either an OE style spring/shock or an aftermarket coil over kit. SPC's arm comes equipped with a stock style ball joint and all of the mounting hardware.
Front Adjustment Range:
Camber -1.00° to +1.00°
Installation time: 0.7 hr/side
67-73 SPC Performance Steel Upper Control Arm for Ford/Mercury Adjustable - spc94210
