Suche Midland Bremskraftverstärker
supersnake
Hallo an Alle,
seit geraumer Zeit ist mein Bremskraftverstärker vom 68er Fastback defekt - die Membrane ist undicht.
Nachdem mir unser User 68GT500 mal wieder geholfen hat den richtigen Typ zu identifizieren habe ich gestern einen neuen bzw. überholten bei rockauto.com bestellt.
Soweit so gut bis ich eben folgende E-Mail aus USA gelesen gelesen habe die mich heute Nacht erreichte:
Hello,
The A-1 Cardone Part # 50-6201 is only available through a Return and Rebuild service (see part description). This means that you will be required to remove your part and send it in to be rebuilt by the manufacturer. The cost of the rebuild is the cost of the part (no core charge) and the shipping charges. The core charge (if present) will be automatically removed prior to capturing your payment OR will be refunded depending on your payment method. You will receive an updated order confirmation in a separate email.
The rebuild time is approximately 3-5 business days after delivery (7-10 for electronics). The turn-around time, with shipping, is usually 2-3 weeks. There is an 80% chance that Cardone will be able to rebuild your part. In the event that your part cannot be rebuilt, a refund will be issued for the cost of the parts minus a $5 testing fee. The shipping charges are non-refundable and the cost of shipping in your order covers the cost of the return trip back to you. We ask that you ship your part via UPS or FEDEX (not mail service) and retain a tracking number for your records. The manufacturer reserves the right to pull another core that is in better condition and send it out to you rather than rebuilding your original part.
If you are returning an ECM, BCM, or MAF sensor for rebuild, and Cardone tests the unit as good, the charge will be $65.00 for testing the part, along with the shipping charges.
Please reply to this email and confirm that you would like to send your part in to be rebuilt. We will provide you with the necessary forms via email.
Thanks,
RockAuto Customer Service
RockAuto, LLC.
1-866-762-5288
Hat vielleicht jemand eine Idee wo ich noch fündig werden könnte?
Vielen Dank.
Gruß Alex
Hello,
Thanks,
RockAuto, LLC.
1-866-762-5288
Vielen Dank.
Gruß Alex
Re: Suche Midland Bremskraftverstärker
Hi Alex,
das kann eigentlich nicht sein, ein Freund von mir hat vor nicht mal 4 Wochen genau so ein Teil geordert.
Es war nach 5 Tagen da - aber leider falsch - auf Reklamation hin, hat Rock Auto nach wenigen Tagen einen (passenden) Ersatz geschickt.
Verfügbar sind sie also noch.
Da dein Auto aber kein 428er Shelby, mit den breiten Ventildeckeln ist, kannst Du genau so gut einen Bendix verbauen...
Checke es einfach ab...
supersnake
Vielen Dank Michael (wie immer), ich werde mich mal mit Rockauto in Verbindung setzen!
Gruß Alex
Gruß Alex
supersnake
68GT500 hat geschrieben:Hi Alex,
Habe jetzt mit Rockauto gesprochen, wenn es mir nicht möglich ist den defekten BKV zur Reparatur zuzusenden wird meine Order storniert!
Gruß Alex
Gruß Alex
- Oldie Fan
- Fuhrpark: -
Oldtimer:
´66 Mustang Cabrio 289
´67 Mustang Fastback 390
´66 VW T1 Sundial Camper
Hi Axel,
können ggf. auch andere Anbieter in Frage kommen, wie z.B.?
http://www.powerbrake-drivetrain.com/se ... 69-/Detail
oder
http://www.autopart.com/brakepowerboost ... USTANG.htm
Gruß Kalli
oder
Gruß Kalli
Member of FMCoG
supersnake
Hallo Kalli
tausend Dank für die beiden links, ich denke das sie beide passen könnten! Habe bei Scott Drake ebenfalls etwas gefunden und den Mustang Teile Händler meines Vertrauens bereits angeschrieben.
Gruß Alex
Gruß Alex
supersnake
Hallo da bin ich nochmal
ich suche also noch immer einen Bremskraftverstärker Typ Midland oder alternativ Bendix ohne Hauptbremszylinder, wer kann mir helfen?
Ich habe "House of Mustangs" schon x-mal deswegen angeschrieben, keine Antwort schade, mittlerweile habe ich mich auch bei anderen Mustang Teile Händlern gemeldet aber leider bekommt man heutzutage keine Antwort mehr auf Anfragen - Servicewüste Deutschland, letzter Ausweg wäre dann echt Order in USA.
Gruß Alex
Gruß Alex
