FRAM PH8A?
SchwarzStock
Fuhrpark: 65 Fastback
FRAM PH8A?
Beitrag von SchwarzStock »
I have used FRAM PH8A filters on all of my Mustangs and 6 cylinder Jeeps. I want to change the oil here soon and need of course a new filter. If I don't use a FRAM what do you guys recommend?
SS
AchimSabi
Fuhrpark: Mustang 1968
Re: FRAM PH8A?
Beitrag von AchimSabi »
Motorcraft FL-1A
SchwarzStock
Re: FRAM PH8A?
Is the Motorcraft filter in some way better or just easier to get in Germany?
Elhocko
68 Mustang Coupe ROC
81 Vespa 200 PE
86 Scirocco GTX
20 Model 3 AWD LR
Re: FRAM PH8A?
Beitrag von Elhocko »
As far as i know, most of the filters don't have an anti drain-back valve.
The Motorcraft FL-1A should have this valve.
Mfg
Benni
Re: FRAM PH8A?
Dazu gab es mal einen schönen Bericht im FoMoCo Forum :
https://www.fomoco.eu/technische-inform ... -t267.html
Danke an Henk dafür.
