I have used FRAM PH8A filters on all of my Mustangs and 6 cylinder Jeeps. I want to change the oil here soon and need of course a new filter. If I don't use a FRAM what do you guys recommend?
SS
FRAM PH8A?
- Fuhrpark: 65 Fastback
Re: FRAM PH8A?
Is the Motorcraft filter in some way better or just easier to get in Germany?
- Elhocko
- Fuhrpark: -
68 Mustang Coupe ROC
81 Vespa 200 PE
86 Scirocco GTX
20 Model 3 AWD LR
Re: FRAM PH8A?
As far as i know, most of the filters don't have an anti drain-back valve.
The Motorcraft FL-1A should have this valve.
Mfg
Benni
Benni
- Braunschweiger
- Fuhrpark: Ford Mustang
Re: FRAM PH8A?
Dazu gab es mal einen schönen Bericht im FoMoCo Forum :
https://www.fomoco.eu/technische-inform ... -t267.html
Danke an Henk dafür.
